RIAA Curve Distortion EQ
Started by WGTP, December 12, 2008, 04:24:50 PM
WGTP
For those of you old enough to remember, vinyl 331/2 rpm records are "mastered" with substantial bass/mid roll off.  It is a standardized curve used on all 45"s as well.  Nothing magic about it, although audiophiles go nuts worrying about the EQ section in their phono pre-amp.
In the FBL it acts in reverse.  It has multiple roll off points of 500 and 2100Hz.  Modding the circuit is strongly encouraged.
I PROBABLY NEED TO LABLE THIS AS A PRELIMINARY DESIGN SINCE IT ISN'T ON THE BREADBOARD AT THIS POINT IN TIME.   :icon_twisted: :icon_rolleyes: :icon_eek:
http://www.aronnelson.com/gallery/main.php/v/WGTP/RIAA.GIF.html?g2_imageViewsIndex=1
Cool calculator  http://www.kabusa.com/riaa.htm
Stomping Out Sparks & Flames
Ben N
Dave Barber says that it is the key to the Direct Drive--using an RIAA-style eq at the end to restore the bass. (Although the DD is not exactly a bass-heavy pedal, it is less bass-starved than a tubescreamer.
Looks like a nice implementation.
DougH
I designed a pedal with a bass compensation stage on the output. It works real well.
Thanks for the RIAA circuit! :icon_wink:
WGTP
It may have been Dave that mentioned that here on the forum.  I couldn't remember who it was.  There are also op amp FBL versions, but with all the gain 2 op amps produce, I figured passive should work.  You can come up with a variety of curves with the calculator.
Doug, are you talking about this? http://www.aronnelson.com/gallery/main.php/v/WGTP/Sweet16.gif.html?g2_imageViewsIndex=1
It is a cool tone control.
DougH
QuoteDoug, are you talking about this?
No, it's something I did recently that I'm keeping for myself. The bass-comp is an active op amp stage.
Caferacernoc
Ever since I learned that most boutique overdrives have an unused half of an opamp chip in them I am quite surprised that having some kind of "bass restoration" isn't more common. It seems so obvious.
DougH
I agree it should be obvious. But there are a number of "boutiquers" who just copy stuff without understanding what they are doing.
WGTP
I guess you could do the same thing with other types.  For example, the famous Rat Double Leg FBL EQ.  Or, the one in the Blues Breaker, or the Std. Dist +/TS 4.7k/.047uf circuit.   :icon_cool: :icon_twisted:
puretube
Quote from: DougH on December 15, 2008, 10:44:09 AM
semper idem...
