Need 25K pot?
Started by Arn C., November 24, 2008, 08:43:02 AM
Arn C.
Howdy folks!
    I have a small practice amp,  the treble pot goes all the way around,  (it is broken).  The broken pot is 25KA,  I only have 50KL,   could I sub this in without too much problems as is???   I need to fix  this today, as my relatives are passing through this afternoon and I want them to deliver this amp to an uncle who could use this right now.
Arn C.
Auke Haarsma
You can lower the value of the pot with some added resistors.  Check this:
http://www.diystompboxes.com/analogalchemy/emh/emh.html
Pick either tapered or Linear pot, whichever you need.
Arn C.
Thanks!  I ended up putting a 56K across the outside lugs, seems ok!
Peace!
Arn C.
