DIY volume pedal?
Started by rutledj, November 23, 2008, 05:08:54 PM
rutledj
Are there any good plans for a diy volume pedal. I was thinking about an active unit to help control the loss of highs.
I have an old crybaby housing I could use as a housing.
Thanks,
Rut
dano12
I wonder of an LPB-1 would work for you. Dirt simple....
Andre
Paul Marossy
Quote from: Andre on November 24, 2008, 04:22:52 AM
Tonepad's Volume Pedal Retrofit: http://www.tonepad.com/project.asp?id=12
I built that circuit using my own PCB layout. I find that it is noisy by today's standards. My DOD FX-17 wah/volume pedal blows it out of the water as far as the noise levels go.
Andre
My build was noisy too at first.
After I tweaked it to get unity gain in toe down position it was good enough for me.
But then again I'm not that critical about noise because I only play live and do no recording.
Speaking about noise, I once had a Behringer volume pedal.
Now that was noisy. :icon_wink:
