TS switching
Started by drewl, November 24, 2008, 03:01:24 PM
drewl
Got TS10 with an intermittant switching problem.
it fails to switch like 1 out of 20 times or hangs up occassionally.
What usually causes it, a failing FET?
switch is good, all pc board connections are good, I'll have to monitor the FETS and see if they're getting signal when it hangs up.
Momentary switch or flipflop is more likely.
drewl
Well the switch is fine, there's not much to the flip flop circuit, I'm going through it and replacing the components, the 2 transistors, caps and diodes...this thing is annoying.
cheezit
In my experience, even when it doesn't seem to be the switch, it often turns out to be----those switch parts are lame.  How do you know it isn't?  Replacing those is cheap, BTW...check ebay.
