Portable amp for MP3
Started by rasco22862, December 21, 2008, 02:09:46 PM
rasco22862
Hello there. I`m looking for a portable amp (9V) proyect. I was thinking maybe the Ruby Amp can do the job, but is this suitable for the MP3?
I also found this http://www.diystompboxes.com/smfforum/index.php?topic=61480.0 in the forum, but I want a little bit more volume. :icon_twisted:
Renegadrian
you may want to try the TDA2005 - just google it and get the spreadsheet- there's an amp circuit that's easy to build and should give you enough juice...
chilecocula
I've used a bridged ruby (~1W) with my ipod and it can get pretty loud with the right speakers
in conservative stompboxes, tone is neither created nor destroyed, but transformed
rasco22862
Quote from: chilecocula on December 21, 2008, 02:38:31 PM
What do you mean with "bridged ruby"?
Renegadrian
So what about the left channel?!  :icon_eek:
(sorry I am an idiot...)
liddokun
I used a single Ruby with an mp3 once. It was plenty loud...my sister only needed it to take with her to an anime convention. I sent both left and right channel into the single amp.
To those about to rock, we salute you.
cab42
Mac made a portable amp for MP3 a while ago, using an LM386:
http://www.diystompboxes.com/smfforum/index.php?topic=61480.0.
He also made a stereo version, use the seach function to find this.
Regarding bridged LM386's, see an example in runoffgroove.com's Little Gem (and propably in most datasheets for the 386):
http://www.runoffgroove.com/littlegem.html
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
chilecocula
A bridged amplifier is a configuration for creating a larger output voltage swing than that possible with one amplifier by inverting a second amplifier and connecting the load (such as a loudspeaker) between the two outputs (Wikipedia  :icon_mrgreen:). The little Gem MKII is an example of this kind of arrangement http://runoffgroove.com/littlegem.html .  Of course the amp is mono and the left channel is ommited, but it sounds good anyway.
chilecocula
#9
double post...
mac
The 386 is a good choice because it can be loud with efficient speakers and batteries last a long time.
386s can also be bridged.
The stereo version has a little more output, but you need a bigger box, etc.
I prefer mono.
I´m working on a better way of connecting the mp3 to the 386 to solve impedance issues and saturation.
Also experimenting with a BD139/140 to get 2w or so.
mac
rasco22862
OK. Last question: What specification should i look in a speaker for this "Ruby MP3 Amp"?
mac
Both lm386 and bd139/140, and many other chips, can work with 4 and 8 ohm speakers. If you want to make a 2w amp pick one rated 4w or more. The better the speaker the more output, that is, connect a ruby amp to a chip speaker and then to a 12" celestion and you'll notice the difference.
mac
