Interesting Remote Control Circuit
Started by tranceracer, January 03, 2009, 02:58:58 PM
tranceracer
I found this AC remote device at a local store and picked one up thinking I could mod it to run only on DC (batteries) to eventually control my rig remotely w/ out wires.  I figured that has a step-down transformer and a diodes and caps for the DC to feed the receiver ckt.
When I opened it up, the ckt doesn't have a step down transformer!  Does anyone know how they are stepping down the voltage from 120V down to I presume 9V to 12V DC to operate the relay and ICs?
I'm wondering if this may be a better way to step down voltages with the help of a voltage regulator than to use a xformer? It would make for a much smaller footprint for an AC/DC converter.
Does anyone think this may be a plausable alternative to a transformer?
It'd be interesting to hear any opinions on the Pros and Cons.
It's a great alternative - except you'd get electrocuted.  :icon_eek:
The circuitry is not line-isolated. They just poorly rectify the AC power line to get a minimal amount of power for the controller and receiver to run on. I can't tell from the photos, but I suspect the relay's coil is 120Vac rated as well.
There are lots of ways to step down voltage other than transformers - but none of them isolate you from the AC power line, and the threat of sudden death.
tranceracer
Thanks RG!
Very interesting!
The relay is rated at:
10A 30VDC
10A 250VAC
15A 125VAC
COIL: 12V DC
Since the coil is rated at 12V DC then I guess they are stepping down the voltage to 12V.
Yes, either stepping down to 12V or current limiting to the right value. You can current limit with a capacitor and not waste any power in the step down like you would in a resistor. Or it may be a small step down regulator, even if that's more expensive.
