Twincaster with Pentaboost "Tap"
Started by sweetwilly, October 09, 2008, 10:11:49 AM
sweetwilly
Have done a quick layout based on Adriano's (Renegadrian) layout, leaving out most off board parts as I haven't changed a great deal, and added an in and out between the tube stages that can be connected to a boost of choice (Pentaboost in my case.)
And this would be the switch wiring for the 2.  The cut tracks down middle represent 2 seperate boards.
Any problems anyone can see?
Cheers.
mth5044
so you think a boost sounds better between the tube stages rather then before or after the tube circuit? Any clips?
sweetwilly
Well, I was planning on housing a Twin and a Pentaboost in the same tin and after reading Diamond Dog's post over in the original Valvecaster thread (page 41) I thought   I'd give it a try.  Easy enough to switch back to the Pentaboost before or after if it doesn't work out!
mth5044
Good deal. As we are going to do basically the same project, let me know what works out for ya. I've got an echo base to build before I get on this  :'(
sweetwilly
Funny, cos an Echo Base is next on my list after this one.  Great minds huh?
mth5044
Aha what are the chances!?
Good stuff.... shall we... race?  :icon_lol:
Nah rushing things never turns out well.
sweetwilly
Hard not to get a bit. er, ernthusiastic sometimes.  Walk before run n'all...
Just figure I can squeeze the Penta circuit (incl tube and heat sink) onto the same board as the Twincaster I've semi-built.  Sweet.  Just waiting on some tools to get my enclosure ready and will be set to fire it up.
Renegadrian
nice project Willy, I want to see how it ends... :icon_wink:
Mind you, altough I triple checked my layout, I haven't build it yet, so take it as UNVERIFIED.
But hey it should be correct...Lemme know, right?!  :icon_wink:
sweetwilly
#8
There's only 1 way it's going to get verified I guess!  I've only made minor changes, mainly to fit the send and return to the Pentaboost in, but also because I have a bit of room to work with.  Still only built a couple of pedals now so is easier to debug a slightly roomier board!
Will post some pics soon.
mth5044
Sorry for the bump, but I need results!
:icon_mrgreen:
