How does a spring reverb work? And how do you design one?
Started by Zben3129, November 17, 2008, 07:10:11 AM
Zben3129
Hi everyone,
I recently cannibalized a Behringer keyboard amp and obtained an unidentifiable verb tank. Its got 4 (2? just joined at the center by the wire thing) springs. The problem is it doesn't have serial numbers or markings anywhere, so I can't determine the impedance. I measured it at 95 ohms input and 375 ohms output. The amp had been solid state and looked to me like it has a 4558p driving the verb. (only thing in the reverb section).
What are the basic parts of a spring verb circuit? Driver, tank, recovery, and blend (and of course power section?) If so, could I design my own reverb around this tank? I need some help on this one, as I don't even know where to start.
Zach
DougH
drewl
Since this is a pedal forum I spose you'll want to go SS, just look at a Fender Blues DeVille/Deluxe or any of their solid state reverb circuits. That will save you some time.
The Accutronics web site has a wealth of detail about spring reverbs (what a surprise!) and a number of suggested circuits.
Zben3129
Thanks guys,
Interesting info I found on the Accutronics site is that the DC resistance of the transducers is nothing like the impedance. For example a 10 ohm input impedance reads .8 DC ohms.   Maybe this is a usable reverb tank after all
Zach
Zben3129
Hmm...
Is there any such thing/difference as a "guitar level reverb" or an "amp level reverb"? As I know 99% of reverbs I have encountered are in an amp itself (only ever seen 1 seperate reverb from amp, besides digital). Is it possible to make a tank reverb that could be used in an effects chain? With a mix to mix wet and dry? Or do they only run at amp (Line?) level?
Zach
solderman
Hi
just happend to stumble on this thread.
If its still interesting, this is a killer project for a effect pedal type external Spring reverb tank.
http://gaussmarkov.net/wordpress/circuits/spring-reverb/
The (my) result
//Solderman
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
It is quite possible to produce a pedal that brings the guitar signal up to a level suitable for driving springs.  That's the easy part.  The hard part is figuring out where to stick the springs and what to stick them in.
