Help Wiring DPDT w/LED
Started by aChorusofJays, February 08, 2009, 06:24:11 PM
aChorusofJays
Hey guys, I'm wiring up my Feedback Looper using the Beavis layout, but I'm substituing the SPDT for a DPDT switch. One so I can step on it, two because I'd like the LED. How would I wire this? I've been searching, and all of the explanations I've found have been over my head (embarrasingly). Could someone walk me through this one? :icon_rolleyes: ???
Andi
Just the same way as the right-most column of lugs on the 3PDT footswitch. :)
So centre to ground, top to resistor to LED to 9v.
Make sense?
Fuzzy-Train
^ Yeah pretty much like the way Andi mentioned. Wire like it is to the right of the red line I added.
THERE IS NO SIG.
The user formerly known as NoNothing.
Stuff I built!
http://s174.photobucket.com/albums/w106/Cpt_sergeant/?start=allRandom
Kearns892
http://www.generalguitargadgets.com/index.php?option=com_content&task=view&id=33&Itemid=27
This GGG site has a ton of simple diagrams for bypass options, The layouts are fairly simple and the graphics on them aren't great, but you should find what you're looking for.
