BMP issue
Started by jacobyjd, February 08, 2009, 04:01:18 PM
jacobyjd
So I built a big muff pi using torchy's layout, and it sounds great--however, it does not quite reach unity gain with the volume pot at full blast.
Would this problem be caused by any of the following parts substitutions?
all 15k resistors were replaced by 12k (what I had on hand)
all 1uf caps were replaced by .1uf
2n5088 transistors used throughout.
  Parts substitutions don't look like they could be responsible for lower than unity output.
  I'd go through and check transistor bias's.
jacobyjd
cool--I'll check out the biasing--it's a tight layout, so I didn't go there right away. Thanks for confirming my thoughts :)
ayayay!
#3
Quoteall 1uf caps were replaced by .1uf
Seriously?  Yes, that would make a huge difference.
edit:  I'm confused.  The schem I saw had all .1uf and a .001uf.  Can you post/link the layout please?
The people who work for a living are now outnumbered by those who vote for a living.
