2SC1815
Started by Rayman, March 03, 2009, 09:03:33 AM
Rayman
Does anyone know if a 2N5089 is a good replacement for the 2SC1815 in a tube screamer build?
Should work fine. The two transistors are used as emitter followers; in this configuration most small signal NPN transistors should work OK if not great. 5089 will be great.
Get the pinout right! The pins are in different order on the 2N5089 from the 1815. The 5089 is EBC, the 1815 is ECB.
Gila_Crisis
yes, 2N5089 or BC550 works fine  ;)
Rayman
Would there be an audible difference?
No. Probably not with any NPN silicon with a gain over 200.
Rayman
OK, thanks for your help
