Effect works, but is humming
Started by SanderNijland, February 16, 2009, 03:45:47 PM
SanderNijland
I build an LPB2 on a custom made PCB, everything works fine except that the effect is humming. If its just plugged in, but turn off and the amp is set to clean, it hums slightly. If the effect is turn on, it gets louder, also on the clean channel. But if i add some distortion/overdrive, it hums like hell.
I build it according this schematic/layout:
http://www.generalguitargadgets.com/pdf/ggg_cb1_sc.pdf
http://www.generalguitargadgets.com/pdf/ggg_cb1_lo.pdf
I used the following parts (maybe those are low quality ore something and make the effect hum)
Resistors - 1/4 Watt, 5% Carbon Film
Capacitors, Panasonic Low Voltage Poly Film
Voltage's
According to GGG:
Collector 4.7v
Base 0.8v
Emitter 0.2v
My own:
Collector 5.35v
Base 0.7v
Emitter 0.11v
Maby something wrong with some components?
Kearns892
Not to sound condescending, but first check your grounds, and what are you using for a power source?
SanderNijland
Using a battery, and what do you mean with check the grounds? I checked every wire and i wired it up correctly. Lets me look over it again one more time, just in case...
jefe
Is it all packaged up in a metal enclosure, or is everything still out in the open?
SanderNijland
No enclosure, that can be the problem?
jefe
It sure can! A properly grounded enclosure can block quite a bit of hum.
SanderNijland
And can you explain that a bit more? The " A properly grounded enclosure "
Ripthorn
A properly grounded enclosure is either a metal enclosure with the enclosure connected to ground or a non-metal enclosure lined with conductive foil or paint that is connected to ground.  This essentially makes the enclosure like a faraday cage used to block electromagnetic signals from outside the cage.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
biggy boy
#8
Watch our for ground loop in your gounding path.
GRD_ _ _ _device_ _ _ _device_ _ _ device_ _ _ _device  OK
GRD_ _ _ _device_ _ _ _device_ _ _ _device_ _ _ _device_ _ _ _GND    NOT   good. This is a Ground loop!
GRD_ _ _ _device_ _ _ _GRD  NOT  good This is a ground loop!
GRD_ _ _ _device   This is good it's the star gound !
| |_ _ _ _ device
|_ _ _ _ _device
Glen
SanderNijland
Thanks guys, going to try this real soon, will report back  ;D
