IC-based 7-watt amplifier bias voltage
Started by Lame, February 23, 2009, 04:17:42 PM
Lame
Hi! What I have to do with that Vbias-thing? Where do I connect that? I know that it is explained somewhere but I need clear instructions. Could someone draw me some kind of picture or something? That circuit would be useful for my tube pre-amplifier.
grapefruit
If you have VDD/2 available connect it to that, otherwise put a 100k resistor between pin 6 and 6, and also pin 4 and 2. This will bias it at 1/2 VDD which is the maximum. If it goes near ground the amp will shut down.
Check the datasheet....
Stew.
brett
Hi
Quotepin 6 and 6, and also pin 4 and 2
That should probably read pins 6 and *2* and also pins 4 and 2.
good luck
Brett Robinson
grapefruit
