PT2399 flaws?
Started by Pedro Freitas, February 25, 2009, 02:14:56 PM
Pedro Freitas
Hello!
I finnished a Rebote Delay and can't get the thing to work properly, the delay signal is distorted.
I've checked everything a zillion times and can't find a bad trace, solder bridge, misplaced component,
faulty battery,... nothing :icon_cry:
Straight signal goes through to the output jack clean and also goes up to pin15 of PT2399 clean.
At pin 12 I got the delayed signal but distorted.
Is there any known PT2399 defect that does this? I got 10 from Ebay and they all do this  :icon_evil:
Or should I continue probing 'till my eyes fall out of their sockets?
Regards,
Pedro
Please vitist: http://www.memoriar.org/
cloudscapes
some clips would help us determine if it's the natural dirty "quality" of the chip or something else wrong
does it get cleaner as you lower the delay time?
{DIY blog}
{www.dronecloud.org}
Pedro Freitas
Quote from: cloudscapes on February 25, 2009, 06:12:59 PM
Ok, I've built a few other PT2399 effects and know how it's supposed to distort.
It doesn't get much cleaner with lower delay times. Sounds like it's internal preamps are clipping the signal or something.
Feedback resistors for the internal preamps are correct. Lowering the guitar signal doesn't reveal anything.
I'm about to shoot at it  :'(
WLS
What was the name of the outfit selling the bad chips???
Since I've breadboarded it I can only blame myself.
But It's Just A Chip!
MikeH
Sounds like you've got a problem somewhere- I had a rebote do something similar because I had a solder bridge.  The delay worked, but it was a distorted and noisy.  Once I fixed it it worked fine.
smallbearelec
Quote from: Pedro Freitas on February 25, 2009, 02:14:56 PM
Bad lots of PT2399 are a known issue! I had bought 5,000, and 80% turned out to be defective in various ways. I was fortunate, because the seller was a company I had been doing business with for many years, and they made good. The replacement lots cost me double, but it is worth it; they are known to be from the Princeton factory, and I have had no complaints.
Regards
SD
alex frias
Did you try to replace th IC for another PT2399?
Pagan and happy!
German
Is the voltage right? Do you have a correct 5 volts on VCC?
Pedro Freitas
Quote from: German on February 26, 2009, 12:41:35 PM
My batch of 10 are marked PTC, I guess that makes them Princeton's?
I bought them from Allpartspipe, on Ebay.
And yep, the 5VDC are correct.
Thanks for the input!
Pedro
German
Could you please place a LED on 12-11 pin and 10-9 - directly on filter caps.
That will help a bit with clipping and also will indicate an input distortion.
