dyna comp mod help
Started by musiclikscreams, April 11, 2009, 02:27:26 AM
musiclikscreams
i wanted to mod my old dyna comp to be true bypass and have an led.  i already added a 9v jack.  it the version w/ the cream colored pcb if that makes any difference
solderman
Hi
This article describes the stompswitch mod for a Cry Baby Wha but the principe is the same as long as the effect does not have the BOSS style transistor switching. As i remember it yours do not. I did the same thing to an old MXR phase 45 with good result.
http://www.stinkfoot.se/andreas/diy/mods/dunlop.htm
Thee is tons on info on how to do this on this forum if you search
//Solderman
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
If it is an old dynacomp with any collectors' value, it would be much better to build an external true bypass box with an LED and leave the pedal in original condition.
musiclikscreams
already did the monte allums and drilled a hole for the 9v adapter.  its not a script so it has no value really
