Is there such a thing as...
Started by David, April 14, 2009, 04:13:03 PM
David
I'm wondering if the following component exists.  I can make it (and probably will have to), but I just wanted to see if it existed...
I know there is a Vactec optocoupler that has one LED driving two LDRs.  However, IIRC, those LDRs are in series so they look like a pot.  I'm curious to see if there is an analogous device where one LED drives two fully-independent LDRs.
mdh
The  Hamamatsu P873-13 (Small Bear has it) is like that.  It's the photocoupler that's used in the Mutron III envelope filter.
David
Nice catch, Matt.  Thanks!
Pricey little cuss, though...   :o
What would be wonderful would be a 2-LED/2-LDR unit that resulted in one LDR going lower in resistance when the other went higher.  The two LDRs could then be linked at a virtual "wiper".
biggy boy
So something like the circiut on the left, but make it with pots to ajust the flash rate and depth.
Then jam two LDRs up to the LEDs?
mdh
Quote from: David on April 14, 2009, 04:48:00 PM
Yup.  I plunked down for one when I built my Mutron III clone, because I didn't want to mess around with the other options, and I had already wasted more than $7.25 of time messing around with horribly matched single optos on the breadboard.
