Adding resistance to negative leg of LED
Started by gmr1, April 29, 2009, 07:23:05 AM
gmr1
I've seen some switch diagrams that do this. Any disadvantages to this? If I'm using 8.2K when wiring using the positive side, when I switch it to the negative, should it remain the same? I like the idea, as it allows me to add the LED resistor to the switch, making it easier to solder...
~arph
gmr1
John Lyons
Yeah, either side is fine.
I've made pedals and after I have everything put together
wanted to change the LED brightness ti match two LEDs
I put a little resistance on the neg side and that balanced the
brightness. You can use resistance on either side.
John
Basic Audio Pedals
www.basicaudio.net/
Nitefly182
Yup its about the voltage flowing through the led, not just into it.
Quote from: Nitefly182 on April 29, 2009, 12:50:39 PM
It's about the *current* flowing through the LED.
A hard to believe axiom is that the currents and voltages of any two electronic components in series is not affected by the relative order of the two parts.
