how to wire a mono in / stereo out bypass
Started by ech0es, May 08, 2009, 09:16:11 AM
ech0es
If i only have a 3PDT and without a led, is it correct:
I want to build this thing:
http://www.loop-master.com/product_info.php?products_id=94
thanks a lot guys
aziltz
that is effectively a Y-Splitter in off-mode.  not the best idea.  you might want to look into adding a buffer or two.
MikeH
What you've got there is probably the same thing as in the link, because they say it will work without power.  But yeah, just passively splitting the signal like that isn't the best way to do it.  You could improve on the design by buffering the outputs.  Of course if you're running a buffered pedal right afterward it doesn't matter.
nelson
You could wire it with an LED if you used RG's millenium bypass.
My project site
Winner of Mar 2009 FX-X
