Which knobs and pots fit?
Started by valdiorn, June 15, 2009, 07:51:35 PM
valdiorn
I'm starting to order some crap for my next couple of builds, I've decided to buy several of these pots from smallbear:
http://www.smallbearelec.com/Detail.bok?no=692
I'm looking for some nice knobs that might fit these, found these but not sure if they fit a solid shaft, or only the split-shaft type of pots... can you tell me??
http://cgi.ebay.com/PCK-20-1-4-17x17mm-SILVER-ALLOY-KNOBS-BOSS-AMPS-PEDAL_W0QQitemZ290047107800QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item438827a2d8&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
MikeH
The pots in the small bear link are solid shaft, and most likely will not work with the knobs in the ebay link.  Small bear sells all kinds of knobs that will go on the solid shaft pots; pretty much anything with a set screw.  They also sell split shaft pots, I think.
