hi, can you wire a DPDT to be a DPST ?
Started by bobster, July 04, 2009, 06:20:21 AM
bobster
hi folks ,
can this be done? i have a dpdt but my wah needs a 4 lug dpst only. i dont want / need true bypass and the dpdt wired normally is causing a loss of signal .
thanks - bob
You just use the 2 middle lugs and 2 of the outside lugs. Depending on how the switch needs to be wired you'll need to figure out which outer ones to use because it might not be the same for both halves.
