Sweet Honey Overdrive voltages/debugging?
Started by wpkg, January 25, 2012, 08:55:44 PM
wpkg
Hello
I am trying to debug a SHOD clone I am making from the schematic and vero board layout here:
http://revolutiondeux.blogspot.com/2010/06/mad-professor-sweet-honey-overdrive.html
Does anyone know what voltage readings should be for Vr, Vb and each of the pins on the opamp? And if there are any other key areas I should meter? I get no sound at all but the volume knob does raise and lower the level of hiss, if that helps figure out where to look for trouble.
Thanks very much!
VR is +8V, Vb is +4V. All opamp pins at 4V, except one at zero and one at +8V.
