Confusion on capacitors
Started by Skulduggery, July 17, 2009, 01:42:10 AM
Skulduggery
I'm building a very simple treble booster, and I've run into some confusion with the capacitor..er..capacitance.
The schematic clearly says 2nf, which I am pretty sure means .002 uF, correct? However, I can't find this capacitance anywhere, not even mouser. Is it possible to substitute the caps with, say two .001 uF caps in parallel? series? Or can I just put .0022 uF in there and no sweat it at all?
Thanks for the help, it's just such a pain having to order from 5 different online shops to get the parts I need for one pedal. Shipping alone  :P
BAARON
2nF means 0.002ųF, yes, and if they Do exist, they're definitely not common.  2.2nF will do just fine: most caps in that size range have a tolerance of ±10% (or thereabouts) anyway.
Ordering from 5 shops, eh?  You could try ordering from One shop... www.SmallBearElec.com probably has most everything you need, to state one example.
B. Aaron Ennis
If somebody makes a mistake, help them understand what went wrong.  Show them how to do it right.  Be helpful.  Don't just say "you're wrong, moron."
Skulduggery
Quote from: BAARON on July 17, 2009, 01:50:44 AM
Thanks. And I love Small Bear, it's my knob heaven. However any conversion chart I find doesn't seem to explain where "mf"s fit into the scale of things, and that's all SmallBear lists their caps as.  ???  I'm so wet behind the ears I might fry my circuits anyway.  :icon_lol:
Skulduggery
Yes nevermind, they are the same thing, huh.
Mike Burgundy
Quote from: Skulduggery on July 17, 2009, 01:59:12 AM
This confusion crops up every now and then, see http://www.smallbearelec.com/Ordering/ProdFAQ.htm , under the header "capacitors".
mF *officially* is milli-Farad, but since there's no "mu" on a western keyboard,microFarad is often written as mF. Most people here use the uF which kinda looks like a "mu". Smallbear however uses mF, so a 1mF=1uF=1μF=1000nF.
Hope it helps!
Top Top
Here is a cap chart I use to help myself be less confused about all the abbreviations and conversions :)
http://www.justradios.com/uFnFpF.html
R O Tiree
Press and hold the ALT key while you type 0181 on the number pad, then let go of the ALT key... µ
...you fritter and waste the hours in an off-hand way...
Paul Marossy
Quote from: Top Top on July 18, 2009, 08:25:35 PM
That's the same one that I printed out and refer to all the time.
