Pcb board headers and wire
Started by trixdropd, August 08, 2009, 05:27:44 AM
trixdropd
I've searched and read all night. I wan't to have some maybe 8-10 pin connectors to put on two pcb's, through hole. Then I need a wire assembly to connect the two saving ions of soldering time.
I've scoured, can someone show me some mouser links or somewhere else in the states of the connectors and wire? I find lots of ones like these: http://www.molex.com/pdm_docs/sd/022281120_sd.pdf
which are great, but I can't seem to find the mating cables. I need maybe 3" cables with ends to plug into headers like those. I guess I don't know what exact terms to use, so help!!
Thanks!!
head_spaz
All Electronics sells something like that....
10-PIN CONNECTOR W/ HEADER, .1" SPACING
CAT# CON-2410
$2.90 each
Probably not exactly what you're looking for... but you could cut the wires to length, then solder the remaining wires onto one board, and use the header/ connector end to connect to the other board.
I've never been able to find them at Mouser... though they probably do have them.
Deception does not exist in real life, it is only a figment of perception.
trixdropd
Thank you Head Spaz...
Anyone else using these or have any other suggestions?
