KPS104A sub
Started by dorothegreat, April 07, 2010, 10:43:07 PM
dorothegreat
hi!
can anyone have any information on this fet? i've tried searching for a data sheet for this and to no avail.
it is used similar to j201 and 2n5457 fet emulation pedals. maybe better is a direct  replacement for such.
thanks! :icon_biggrin:
Zapp Brannigan
Here you go:
http://www.platan.ru/pdf/ec79-82.pdf
КПС 104 А in Cyrillyc, or just seek for the 24th line in the list.
It is N-channel fet, Uds max~25 v; Ugs max~1 v; Pdessipation~0,045 W; S~1mA/V. Actually this is not a single Jfet, but two transistors in a single case.
Here's a picture of its pinout, you need position 5^
http://www.rlocman.ru/datasheet/data.html?di=59143
Pins are (if we start from mark counterclock-wise) S1-G1-D1-S2-G2-D2.
It may be substituted with two identical j201 (you'll have to select them by cut-off voltage and drain current).
dorothegreat
thanks for the info Zapp.i owe you big time.  :icon_biggrin:.
and its your first post i think. i found a schem for an emulation pedal
and it was from a Russian site, just recently finished my first dr boogey (unboxed yet)
and would try another high gain pedal.
Zapp Brannigan
You're welcome. Yes, you are right, that was my first post. :icon_biggrin:
May I ask you what scheme did you find? This one:
http://www.sugardas.lt/~igoramps/article68/article.htm ?
Or one of these:
http://www.guitarjfet.ru/index.php?option=com_content&task=view&id=30&Itemid=34 ?
Anyway, if you'll have any problems with them, I can post here a link to a russian DIY forum where the authors of all that stuff are usual guests and they wouldn't mind to help you.
CLAAS
