Boss slow gear not wanting to go
Started by sean k, October 10, 2009, 09:42:43 PM
rousejeremy
I built a slow gear using the Cathexis vero. It works, but I won't bother boxing it up. A volume pedal is really the way to go.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
MarcoMike
mh... not sure... for long swells the volume pedal or the guitar pot are probably enough/better... but it's fun to play with it!
Only those who attempt the absurd will achieve the impossible.
sean k
Now if you could get the swell pedal to be have the timing of the swell driven by the hardness of your playing... that'd be quite useful. Pick soft for a little cut of the initial attack and pick hard for long slumbering swells... that'd be well nifty!
Monkey see, monkey do.
Http://artyone.bolgtown.co.nz/
oldrocker
A cool use for the SG-1 is after a tremolo.  If you're looking to smooth out a choppy trem the Slow Gear does it well.  I used after my Pulsar and it worked great for that.  Also an SG-1 in combination with other effects like phasers and chorus and or delays you can get a convincing organ type sounds.  A one trick pony maybe but if you use your imagination you might find it useful.
