Millenium 2 Plus Questions for switching several leds
Started by Carlos Best, September 09, 2009, 11:23:16 PM
Carlos Best
Guys
I'm starting to clone a Sansamp Gt2
After reading some things about the circuit y decided to use bicolor leds for the 3 selector so you could go from green-amber-red acording to the simulation, mic position, etc
I tought to combine this idea with the millenium cause it's imposible for me to get a 3pdt were I live.
Analyzing the fet its just a fancy switch that connects the led to ground when its pulled down with tha output of the circuit
heres the circuit I designed.
The questions are: I am right with these supositions? :D Or, will it work?
The 2N7000 will be ok with the consumption of the 6 leds (in case they are all in the amber position) running trough it?
I also used one of the variants of the millenium, that grounds the input of the circuit to avoid oscilations (a must with this high gain circuit)
Cheers
Coco
Quote from: Carlos Best on September 09, 2009, 11:23:16 PM
The MOSFET pulls the LEDs to ground when the control line is NOT pulled down by the output of the circuit; this is the reverse of what you said.
QuoteThe 2N7000 will be ok with the consumption of the 6 leds (in case they are all in the amber position) running trough it?
The 2N7000 datasheet tells you the maximum current and power dissipation.
Carlos Best
Thanks RG!
I took a peak on the datasheets and it says
2N7000
Continuous Drain Current = 0.2A
so asumming each led consumes a maximum of 30mA
30x6=180ma
It's safe ok?
The BS170 is tougher. It says 0.5A of Continuous Drain Current. mmmm
http://www.datasheetcatalog.org/datasheet/vishay/70226.pdf
