Has anyone tried Stenciing
Started by aziltz, September 16, 2009, 09:27:24 AM
aziltz
Quote from: peps1 on September 17, 2009, 07:28:56 PM
Just had a thought  ;D
Have you got a laserJet printer? if so you can use the "toner transfer method"
Just print out you POT labels and any artwork onto a sheet of gloss photo paper (or a page from a glossy magazine) flipped horizontally.
then place the print out toner side down on your pedel and run over a house hold iron on its hottest setting, really lean on it and give it a good going over for about 5min. (the page will stick to the pedal)
Then place in warm water till the paper peels away, rub over with a toothbrush to get the remains of the paper off and you should be left with black printer toner letters boned to your pedal......seal with a lacquer, and its done!
you can get really thing detailed lines using this method, and it how I make PCBs.
(if photos would help illitrate ths, just let me know and i will go take some!)
i have access to a laser printer, and I plan on learning how to etch my own pcbs soon.  It sounds like a good idea, but I would worry about the heat messing up the finish on the pedal.  Should I be worried?  I usually use PPP's powder coats.
Also, I don't necessarily want black.  I found those custom stencils online.  I'm gonna give it a go with those and some temporary spray adhesive, any suggestions?
peps1
Quote from: aziltz on September 17, 2009, 07:37:40 PMIt sounds like a good idea, but I would worry about the heat messing up the finish on the pedal.  Should I be worried?  I usually use PPP's powder coats.
I have no clue  ;D but im doing some test right now with plain aluminom and painted to see what effect the heat would have.
will be good to see how the custom stencils come out, I personaly would you a Scotch Low Adhesion Masking Tape to hold them down and mask off.
aziltz
thanks, scotch should be easy to find.
