wiring 2 effect together...???
Started by Bullet79, October 03, 2009, 04:32:35 PM
Bullet79
HI..
Could sombody show me how to wire 2 efx in one pedal.. (with single 9v)
thinking of joining LPB1 pcb with MXR micro amp.. kinda boost/solo switch...
.Mike
This has been covered many, many times.
Hit the Search button at the top, type multiple effects or multiple wiring or multiple enclosure and start going through the results. You'll probably find a few dozen topics that answer your questions, some with links to wiring diagrams that will show exactly what you need to do.
If what you're trying to do isn't covered, post back and I'm sure you'll get some help. :)
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
Top Top
I second what has been said about searching, but just to give you a basic idea, it is very simple as long as both effects are designed to run off the same voltage level and polarity.
Essentially you just hook the power and ground to both circuits, and wire the output of one to the input of the next.
Do a search though as there may be other issues involved depending on what you want out of it.
boogietube
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
Bullet79
