New Here Needs help
Started by lesde12, October 07, 2009, 10:36:33 AM
lesde12
May i ask how to verify the pin configs
because i have downloaded some schematic
diagrams that has no pin configurations...
here is one of those schematic diagrams...
http://www.rabbathrecordings.com/Distortion.html
as you can see theres the IC
but i dont know the pin config
i don't know where to connect
the other components..
the pin numbers of the IC are missing
plz help me to solve this problem..
more power!
thanks...
aron
Hello! Check out the DIY FAQ and let me know if you need any more help figuring out the pins:
http://www.diystompboxes.com/wiki/index.php?title=DIY_FAQ#OP_AMP
You can use either a single op amp or dual op amp for that project.
Good luck!
