Quicky, pot thread depth
Started by ~arph, November 24, 2009, 05:46:35 AM
~arph
Just a quick question since I'm at work and can't check this now.
Roughly how much tread (mm) is still available on a standard 16mm alpha pot when mounted in a hammond (b or bb)  enclosure?
Thanks,
Arnoud
rustypinto
Total shaft thread is 6.5mm.
Washer thickness is 0.4mm.
Nut thickness is 1.7mm.
Total available shaft when mounted is ~4.4mm.
~arph
Ok thanks!
That would be good I have an idea which requires ~2mm extra height.. Now i know I will still be able to put on the washer and nut.
~arph
btw.. I think you forgot the thickness of the enclosure.. about 2mm..
rustypinto
Quote from: ~arph on November 24, 2009, 11:21:04 AM
You didn't ask for that  ;)
These could go anywhere, limited to a 4.4mm panel.
Paul Marossy
Does anyone know where can you get replacement nuts for the Alpha 16mm pots? I need some...
rustypinto
The mechanical dimension/ designator for this type of nut/ washer is "M7."
Smallbear has them, though it's not clear if they're direct replacements (no datasheet):
http://www.smallbearelec.com/Detail.bok?no=482
Mouser has a hardware page in their "virtual catalog:"
http://www.mouser.com/catalog/catalogUSD/640/2277.pdf
Where i would use (Mouser Part Number) 48AN007 for a replacement nut.
Note the thickness is 2mm thick, 0.3mm thicker than the stock Alpha (although i have not seen a spec for the alpha nut, which i measured. could very well go up to 2mm within some tolerance).
Also note that replacement washers are available from each vendor.
Paul Marossy
Thanks for the info! I thought I was up the creek on getting some replacement nuts.
