Vox V810 Valvetone replacement switch still pops when engaged
Started by Trancedental, November 07, 2009, 10:28:13 PM
Trancedental
I installed a new switch on my old Vox V810 Valve Tone because the old DPDT switch made noisy popping sounds when turned off & on
I wired a new 3PDT exactly the same yet the problem is still there, the switch is wired as before, because I'm not 100% sure of the exact functions of the wiring & how the LED is done on this pedal!!! ::)
1 OUTPUT to Jack            (4)       7 Yellow from PCB?
2 IN from Jack                 (5)        8 GREEN from PCB?
3 Orange to PCB IN?       (6)       9 Purple connected to Lug 1
Original wiring same as picture linked below
http://www.sugardas.lt/~igoramps/voxvalve.htm
Anyone know an easy way to get rid of this popping noise when I switch the pedal on/off?
Thanks JK
Trancedental
Trancedental
Darrons 3PDT wiring scheme worked perfectly first time & I'm sure the pedal actually sounds better, maybe the extra ground wire made the difference because it seems to have more air & sparkle than before? Cheers Darron! ;D
Still swapping out various opamps & will be trying a few more mods along the way though!
zombiwoof
As I recall, that pedal used the Millenium bypass in stock form.  I have one, and don't remember having popping problems, but I haven't used it for a while.  I'll have to get it out and check it.
Thanks for the info.
Al
