Looper with passive blend pot?
Started by SebaMozo, November 17, 2009, 10:06:15 AM
SebaMozo
Hello, i have a true bypass strip, but i want to blend dry and wet signals.
can i do with only a 500k pot conecting one lug to the hot of the dry signal, the other lug from hot of wet signal and the middle lug to output of the loop (in the 3pdt switch)??
Thanks.
MikeH
Passive blend almost always = signal loss.  The Splitter-Blend project at ROG is a buffered signal splitter that can be used to blend between 2 different effects, or you can jumper one channel and it will blend between one effect and your clean tone.
A good setup is to build it with the 2 loops, but on the second loop use a switching jack so that if there is nothing plugged into the loop, the send on that side is 'jumpered' to the return, and then you just have a wet dry blend for one loop.  That way you can use it both ways.
