true bypass switching with relays? what are your thoughts?
Started by knealebrown, November 30, 2009, 10:32:52 AM
knealebrown
Hey Guys,
Has anyone designed/built a true bypass unit using a relay and a latching switch instead of the standard 3PDT switch?
I realize there are simpler ways to build a bypass unit however due to my rather large spec i have decided that relays are both cheaper and more practical. Here's my idea:
-Nine loops
-Buffer at input, buffer at output, switchable buffers on each loop (excessive i know)
-Switch to swap loop one and loop two around for fuzz first vs wah first debate
-LED indicator on each loop (5mm) and LED indicator on the switchable buffers (3mm)
Its not too complicated but if anyone has any advice, warnings or ideas then feel free to throw them at me. as always thanks in advance for your input.  :icon_biggrin:
Kneale
''99 problems but a glitch aint one!''
Another non-reader of GEOFEX shows up.
Go read the articles at http://www.geofex.com on programmable/remote effects switchers and relay switching. Any questions that doesn't answer, come back and ask.
