effects chain mixer?
Started by REGNAD, November 20, 2009, 05:13:11 PM
REGNAD
i have a vintage deluxe mistress now and when the effect is on it sucks my tone pretty bad. i tried running the flanged output to another amp and the dry output to my primary amp and really liked the outcome. i still had the balls of the original tone with the mistress riding right along side.... can i do this on one amp that only has one channel? im thinking something like a mixer with 2 inputs and one output, i could then run whatever i wanted times two into my valve jr. does such a beast exist.
ianmgull
B Tremblay
B Tremblay
runoffgroove.com
REGNAD
the runoff circuit looks good but I didn't see part numbers for the componants. particularly the ic chip...
B Tremblay
Check the lower left corner of the schematic.
B Tremblay
runoffgroove.com
REGNAD
got it, thanks. has anyone built this?
B Tremblay
B Tremblay
runoffgroove.com
REGNAD
:P, just noticed under your name! thanks!
MikeH
I have- it's really useful.  The set up I'd recommend is building it wih 2 loops, but to use a switching jack on one loop to short the loop closed if nothing is plugged in.  Then you have a wet/dry blender too.
B Tremblay
That's also how I built mine, Mike.
B Tremblay
runoffgroove.com
Ben N
Try running the Mistress in parallel wit a chorus, and then some delay on one, the other or both, for an impossibly lush sound.
REGNAD
wheres a goos source for the transistor and ic chip? is there any signal loss with this blender? i only see panning sound clips. any in the loop out of the loop sound clips?
MikeH
The components are pretty widely availiable; I don't know what continent you're on, but you could get them at smallbear for sure.  Although any dual opamp, like a 4558, should work fine.
There probably aren't many soundclips around because it's not really an effect on it's own, but more like a tool to enhance other effects. But it's really quite useful.
B Tremblay
Quote from: REGNAD on November 21, 2009, 05:36:26 PM
What sort of clip would better illustrate the circuit?
B Tremblay
runoffgroove.com
Ben N
May I humbly suggest, following my post above, a clip with chorus and flange separately, then mixed in parallel.
REGNAD
ben, i cant seem to find your clip...
