wiring on the gallery Distortus Maximus
Started by scottlynn73, December 07, 2009, 06:35:04 PM
scottlynn73
hey guys- I am trying to build the Distortus Maximus from the gallery and I'm a bit confused about the wiring- on the Low and Master pots it looks as though there is a jumper wire from lugs 1-2 on the Low, and 2-3 on the Master.
Have I got this right? Its not very clear from the picture :) Does lug 2 of the Master maybe go straight to output?
http://www.aronnelson.com/gallery/main.php/v/mnordbye/layouts/Krank+Distortus+Maximus.gif.html
caspercody
When looking at that picture, you are looking at the pots from the bottom. So, the left lug is number 3, and the right lug is number 1.
Low pot there is a wire between lugs 2 and 3. But on the master pot number two goes directly to the output (or on/off switch if you use one).
caspercody
Are you asking me for a schematic?
That is what I did look at to make sure of the wiring.
scottlynn73
thanks for the help  :D  yeah I realised I had mixed up the pot numbering after I posted
