9v from 24v regulated power supply.
Started by ubaid88, December 27, 2009, 04:40:04 PM
ubaid88
How do i  can get 9v from 24v dc power supply unit?
Simple voltage divider like 600k/1M resistors or Regulator or Zener Diode?
Processaurus
For powering a circuit? Regulator.
LM7809 Datasheet  Input voltage can be as high as 35v.
JDoyle
It depends on what you want to do with the 9V - how much current are you going to draw? How 'clean' do you want it? How 'stiff' and accurate does it have to be at delivering 9V?
My quick answer would be a resistor from 24V to a 9V Zener in series with a regular silicon diode; then buffered by a silicon transistor (base to 9V Zener/resistor junction, collector to 24V, the emitter is 9V out: bypass to ground with high value electrolytic cap). The silicon diode provides a good way to balance out the tempco of the zener and the Vbe of the buffer transistor will cancel out it's added diode drop. Consult the zener's datasheet to figure out it's optimum operating current, divide 15 (Vce = 24V - 9V = 15V) by that current value and round down to nearest standard value - that is the resistance used between 24V and the zener. Depending on the current you end up drawing, you may need a power transistor and/or a heatsink, as it will dissipate [15V*(current drawn)] watts. The TIPxx series of power transistors is as good as any and fairly readily available. To bulletproof, sprinkle high value electrolytics at 24Vin and the base of the buffer (or 'pass') transistor - make sure all electrolytic caps have sufficient operating voltage ratings. Keep in mind that the limiting factor in all of this is the current ability of the 24V power source - it has to power both the 9V regulator and the circuit(s) the 9Vout is powering.
I'd say that the above will be more than sufficient for 99% of the guitar circuits out there.
Regards,
Jay Doyle
zyxwyvu
Definitely a regulator. JDoyle's response describes a discrete regulator, but I don't think it's worth the trouble when you can just use an LM7809. Plus, you get added features that a simple discrete regulator doesn't have. As Processaurus said, it can easily handle 24V. The only issue you may run into is power dissipation.
With no heatsink, an LM7809 (TO-220 package) dropping 15V (24V-9V) will be able to handle around 128mA (you can get this from a little math with the max operation temperature, thermal resistance, and P=IV) before is burns up. If you need more current, you will need to either heatsink the regulator, or use an external pass transistor (as described in the datasheet).
JDoyle
My way is definitely more trouble to build, and will take up more PCB real-estate than a regulator based on one of the many ICs available out there.
However, I would maintain that the discrete option is more rugged, less prone to oscillation issues which I have had pop up here and there with IC regulators (though most of my experience is with the 78xxx types), and almost certainly give you a less noisy Vout than an IC based regulator - but that can be mitigated in the IC version with proper power supply bypassing strategies.
I should note that I am VERY biased towards discrete designs of anything involving audio in the signal path - and in the end, the power supply to a circuit is the limiting factor in terms of noise.
If you just want it up and running so you can get on to building the fun stuff though - go with a regulator IC.  :icon_wink:
Good Luck!
Regards,
Jay Doyle
ubaid88
thanks guys.
But i have changed my mind. I will build regulated a 9v supply instead of ripping 9v from 24v one.
