Anyone added the LFO from the echobase to the rebote2.5?
Started by ppatchmods, December 30, 2009, 03:37:32 PM
ppatchmods
Just looking for a simple LFO to add to my rebote. i've looked at the one in the gallery and the trem lune lfo add on. just wondering if any had success with a good sounding and controlable LFO. thanks
When your life is over, will any of this STUFF really matter?
Have a look through the Clarinot thread for the LFO mod.
http://www.diystompboxes.com/smfforum/index.php?topic=74294.0
Change the Rebote's delay pot to 100k, add a depth pot and LDR as in the Clarinot Cubed.
That's one way to do it anyway
ppatchmods
where does the ldr/led go on the lfo mod? it looks very simple. thanks
Quote from: ppatchmods on December 31, 2009, 10:53:32 AM
The LED is marked up in the LFO schematic: http://i210.photobucket.com/albums/bb292/frequencycentral/ClariLFO.jpg
For the LDR you'll need to duplicate the arrangement from the original Clari(not) schematic: http://i10.photobucket.com/albums/a113/midfielectronics/mid-fi_clarinot.png ie, change your Rebote's delay pot into a 100k, add the depth pot, LDR and 1k resistor. You probably won't need the 1k resistor as teh Rebote has one right next to pin 6.
ppatchmods
awesome! 2 questions:
Why is the 100k pot necessary?
What LDR/LED combo did you use?
Quote from: ppatchmods on December 31, 2009, 02:09:24 PM
Resistors in parallel. The 100k depth pot will lower the value of the delay pot, so using a 100k gets it back up there.
LDR: Typical dark resistance = 1M Typical light resistance = 2K - 4K
LED: Super bright white 5mm, but others will work well by varying the 100k resistor marked with a red star in the LFO schematic.
ppatchmods
thanks rick. i've some time this weekend and i'll see if i have all the parts.
