ROG Grace/Big Daddy Potentiometer Question
Started by Pakaloabob, December 31, 2009, 11:23:04 AM
Pakaloabob
The schematic for Grace/Big Daddy distortions on the Runoffgroove website http://runoffgroove.com/grace.html has a "Drive" potentiometer with N.C. written at contact #1. I am not sure what this means. If it were to be connected as a variable resistor I thought that contacts #2 and #3 would be attached together.
Can anyone clue me in?
head_spaz
N.C. typically means No Connection.
In this circuit the potentiometer is wired, and used as a Variable Resistor, rather than it's traditional role of Voltage Divider.
Wired as a variable resistor, it works the same if you connect that loose end to the wiper, OR leave it floating.
I usually connect the loose end to the wiper as you suggest, rather than have it floating and acting like an antenna.
Good luck with your project.
Deception does not exist in real life, it is only a figment of perception.
B Tremblay
When wiring a pot as a variable resistor, shorting lugs 2 and 1 will result in lower overall resistance as the pot is turned up (clockwise).  If you short lugs 3 and 2, the pot will increase in resistance when rotated CW.
In the case of the Grace/Big Daddy, the 1k pot parallels the 386's internal 1k35 gain-setting resistor.  When the pot is at minimum, the overall resistance is about 570 ohms.  As the pot is turned up, the resistance decreases and the gain increases.
B Tremblay
runoffgroove.com
Pakaloabob
Thanks for clearing that up. I guess I was so used to seeing pots wired as variable resistors with 2/3 connected, it freaked out when I saw something different  ;)
