Make LED brighter
Started by Wonderdog, January 06, 2010, 02:00:13 PM
Wonderdog
My LED is wired in to show the speed of my rotating speaker simulator (Dano RR).  It is not very bright.
When I wire the same LED in to show on/off it is plenty bright.  How can I increase the brightness when wiring it in to show speed?
JKowalski
The brightness of an LED is determined by the efficiency of the LED and the current going through it. To up the brightness, either buy a more efficient LED (super bright, hi-efficiency, etc.) or, much easier, just lower the value of the current limiting resistor to let more current through it.
Wonderdog
It needs more current.  :)
The problem is I have it piggybacked/tapped into the speed circuit off the IC so it flashes in time with the speed setting of the effect.
There is no current limiting resistor I can change.
  i can't see the schematic, whether that'd help...
  A transistor buffer output will follow the input voltage drive current and can much less appreciably load the control voltage it's being fed.
So buy a brighter LED.  They are rated in terms of millicandles, usually abbreviated as 'mcd'.  What we generally refer to as "superbright" come in at a rating of around 2000mcd or higher.  While those rated at 6000mcd are harder to find in some locales and sizes, a rating of 2000mcd is pretty common.
Note as well that when you say "brighter" what you really mean is "more visible".  Visibility is a function of color and contrast between LED and background.  A black bezel can help in increasing contrast between the LED the area surrounding it, often permitting one to get by with less brightness.
JKowalski
Give us the schematic, so we can see whats going on with the LED.
If you ever have an LFO you can always either tap it with an LED+resistor to ground or build a quick buffer so as to not interfere with the operation of the circuit.
Wonderdog
#6
I am using an 8mm LED becasue it is cool it is so big, but I can't find a high brightness one.  I suppose I could gut it and put a high brightness one in the larger lens.  I do have a black bezel.
I did short the current limiting resistor.
Wonderdog
Quote from: JKowalski on January 06, 2010, 05:52:39 PM
This may be the thing to do:  the effect has several delay sounds running together and in hooking up the led it mutes one of the audio delay lines, making the effect sound less complex.  I installed a switch to go back and forth.
blooze_man
i dont know what color the LED is now, but i always use blue LED's. no exceptions. they're way more visible than red, which is a common LED color
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
Wonderdog
Quote from: blooze_man on January 07, 2010, 06:48:03 PM
It is ORANGE . . . cool
