Can you check my pseudo vanishing point sequencer layout?!
Started by ugly_guitar_guy, January 09, 2010, 02:06:57 AM
ugly_guitar_guy
Ok, So using the two schems below:
and
I came up with this layout below. The combination of the two works on breadboard and I'm not very good at making layouts so can someone please verify that this is correct for me or give any tips on how to make it better before I dive in and solder it all together? Thanks!
Check out my metal band here: www.facebook.com/hollowshell
or
my personal effects building page here: www.facebook.com/brotronics
daverdave
I haven't had a proper look but one obvious thing is you're shorting the +Vcc and ground pins on the ICs, I can't see where your power connections are either.
daverdave
plus you could do with filling in the black areas with copper islands so as to save on etchant, it's not that important though.
ugly_guitar_guy
Ok, I think I got it figured out (thanks daverdave).
How does this look? It's not the best layout ever, but it should work I think:
or
dr.benway
ugly_guitar_guy
Quote from: dr.benway on January 09, 2010, 07:21:05 PM
looks like the same pic as above.
cause i deleted the first one from photobucket and replaced it with this one ;)
or
ugly_guitar_guy
ok, i get only the first light on and that's all that happens...
C'mon guys, I could really use a little bit of help here. I'm pulling my hair out over how simple this is and I just cant get it on a freaking circuit board.
or
daverdave
I'm sure there should be another resistor between discharge and threshold on that 555 schematic. The value of it affects the mark space ratio of the outputted squarewave. it's possible that all you're getting out of the 555 is a dc signal, I might be wrong. But with you saying that it only lights the first step then I'd assume it's something to do with the clock. I'll have a better look when I can, at the moment I've got to pack to get back to uni.
dr.benway
Similar problems with this circuit combining 555 and 4017  :  http://media.photobucket.com/image/atari%20punk%20console%20with%20sequencer/monstruarte/atari_punk_console4th.png
same thing going on, just one light, then it seemed like a bad solder joint started clicking and sequencing and then it stopped and now i can't get it to work again...
dr.benway
so regarding what daverdave said maybe try a 100k on pins 6 and 7 of the 555
daverdave
I'd say try a few different values, 1k, 10k etc. As it really depends on the range you want. That charge cap will affect that aswell so again try different values.
ugly_guitar_guy
well theres something wrong with the layout that i made because i couldnt get it working, so I found a radioshack pad per hole board that was laid out like a breadboard and followed the breadboard layout i have of the schem above that i posted and got it working. Now its time to work on the audio section...
or
