Enclosure Drill Hole Sizes?
Started by Steve Mavronis, January 30, 2010, 11:40:15 AM
Steve Mavronis
I've been searching through the threads but most help links posted no longer work. All the templates I've found show where to center the hole but not the diameter to drill.
What are standard hole sizes for pots, power jacks, guitar jacks, and footswitch?
I understand you should leave some wiggle room for the pots in case of different brands and hole alignment errors, and I guess the others not too much?
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
boogietube
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
boogietube
Steve Mavronis
Quote from: boogietube on January 30, 2010, 12:37:26 PM
http://www.diystompboxes.com/smfforum/index.php?topic=30945
Quote from: onboard on March 14, 2005, 11:10:20 AM
T1-3/4 LED bezel, mini toggles - 1/4" (6mm)
T1-3/4 LED without bezel - 3/16"(5mm)
16mm pot - 9/32" (7mm)
24mm pot - 5/16" (8mm)
audio jacks - 3/8" (10mm)
footswitches - 15/32" (12mm) for a perfect fit w/o washers, 1/2" is fine if you use the white plastic washer included with 3PDT's, Carlings don't include washers.
realizewhoitis
sweet ive been looking for a couple of those measurements myself...guess maybe i should have written them down after i drilled :P
mth5044
cheeb was kind enough to send me these in October of 08 and they have been sitting in my inbox since then. I use them all the time  :)
realizewhoitis
Quote from: mth5044 on January 30, 2010, 02:56:31 PM
now thats awesome! thanks for sharing. that will be printed and hung on the wall over my drill press
mth5044
Quote from: realizewhoitis on January 30, 2010, 03:43:44 PM
Don't thank me, thank cheeb  :)
