Can I use the millenium bypass for this setup?
Started by compuwade, January 30, 2010, 08:14:40 PM
compuwade
I've been trying to use the millenium bypass wiring for this setup, but with no luck. Can it work? And if so, can someone help me out with the wiring? I want an LED for both switches.
Wade
What you've shown there is wired in compatibly for the Millenium bypass.
If you make each of your bypass switches wire like the Millenium Bypass articles at GEOFEX, and if the place the control line for the Millenium is connected has a resistance to ground of less than 1M, it will work fine.
So I guess the answer to your topical question is "yes, the millenium can work fine for that" so long as you make the wiring right and the outputs sensed by the Millenium have a DC resistance to ground. Beyond that, it's follow the diagrams at GEO.
compuwade
Thank you very much! I added a 100k resistor to ground at the buffer output and that fixed the issue. Everything works great now!
Thanks again,
Wade
