My Fuzz Face will not turn on?? Help !!!
Started by sdlogan9, February 08, 2010, 06:16:07 PM
sdlogan9
So I have buit a few kits here and had good luck with advice...  from members here..  maybe some one can help me with this problem
I have a Fulltone 69 Fuzz Face and when I plug in the guitar and click the on/off switch to passive to let the guitar signal go straight to the amp all is good!!!
here is where it goes bad...  when I try and engage the pedal the signal gets much weaker  (not working ) (no distortion) and the pedal light does not come on??
Any ideas?
Peace
Shane
Top Top
Take a look first at the debugging thread (stickied in this forum)... the advice you will get here will start with the info there.
sdlogan9
Well this is a general question..  I did not build this unit.  It is a fairly standard Fuzz Face..  and I am sure this is something very simple I just have not figured it out.  So if anyone can please give a basic diagnosis for the problem stated in the first post that would be fantastic...  If you really need to see a schematic for this issue then I will get a copy of of the fulltone 69 off the web somewhere..
but this problem is something similar to  no fire or no fuel in a motor of your car.
Peace
Shane
  Sounds like there's no DC reaching the audio circuit.
  Or the LED switch circuit.
  What's the continuity between V+ [battery clip?] and the board V+?, same thing for the negative, one of the two [+ or - ] connects to grounds [jacksleeves when input has a mono plug in it].
  And the pole of the battery that connects to Q1 emitter wins the polarity contest, indicating whether it's a PNP Pos or NPN Neg gnd. circuit.
  At this point it's either fixed or to the fix finder: Debugging, without the required content, there's way too many blanks to equate much of anything beyond I/O doesn't O.
zombiwoof
I'll bet it's just a bad battery snap, those things go bad once in a while from flexing.  See if you are getting any voltage from the wires to the battery.
Al
jkokura
Usually when my pedals have that symptom it's either bad wiring (likely) or a power feed issue (less likely, but still possible).
Is it under warranty? Don't void your warranty by opening it. See if you can contact Fulltone first. If they can't/won't help, by all means open it up and start the debugging thread. I don't see why it wouldn't apply here cause it's essentially the same kind of pedal we all build, just of commercial variety.
jacob
