Changing battery snap for dc 'barrel style' jack in big muff, Center pin -?
Started by knealebrown, February 11, 2010, 12:07:55 PM
knealebrown
Quick question, im Changing battery the snap for dc 'barrel style' jack in a friends  big muff. should i make this dc jack center pin negaive? if im right this is the standard convention yes?
Thanks (still learning ;))
''99 problems but a glitch aint one!''
panterafanatic
You use a 2.5mm center negative jack with a NC switch built in, (unless you don't want any battery option, in which case the switch part isn't necessary.)
-Jared
N.S.B.A. ~ Coming soon
