E.H. Metal Muff
Started by Cardboard Tube Samurai, March 21, 2010, 02:48:35 AM
Anyone got any idea what the polarity protection diode is? To be completely honest, I've never even looked at what diodes are used for reverse polarity protection in any pedal. I've been asked to repair one and it's obviously the problem but due to the nature of it's explodedness (not to mention the fact that it's SMD), there's no way in hell I can identify a part number. If I can't source the correct part, what are some substitutions?
sundgist
The protection diode in mine blew.
It is the smd equivalent of a 4148. The are 2 thruplated holes on the board around this diode and it's easy to solder in a regular 4148 or 914.
I'm at work today but can take a photo tonight of the repair I did. There are manufacturer schems of this pedal floating about also.
If you look at the board, just by the dc socket is what looks just like a regular small diode but without the legs. Follow the traces either side and you should come across the thru plated holes.
Awesome!!! Just the answer I was looking for, thanks!
Is it paralleled or in series?
theehman
Quote from: Cardboard Tube Samurai on March 21, 2010, 05:47:11 AM
Series.  You might want to replace it w/ something a bit more heavy-duty, like an SMD 1N4001.
Ron Neely II
fx schematics and repairs
sundgist
I wanted to use it and found it wasn't working, hence the 'quick long legged repair'.  :icon_redface:
Now i've got it open I might just tidy it up a little.
Not the clearest photo, but the blown diode in question used to sit where it says D2. Holes are just to the left.
Quote from: sundgist on March 21, 2010, 07:03:46 PM
Yep! That's the one. Thanks heaps!!!
