470k pots Vs 500k
Started by peps1, March 22, 2010, 03:33:34 AM
peps1
Out of 500k LOG pots, is it going to make much difference using a 470k? or would I be better off using a 1M LOG bridged with a resistor?
(its a MXR Noise Gate)
Thomeeque
Quote from: peps1 on March 22, 2010, 03:33:34 AM
No, standard pot's value is very casual - tolerance is around +/- 20% (so the real resistance of 500k pot can be anywhere between 400k to 600k), 470k is practically the same thing.. If there was need for precise value (above standard) in the circuit, it would be noted somewhere around.
T.
Do you have a technical question? Please don't send private messages, use the FORUM!
peps1
Thomeeque
You're welcome, good luck! :) T.
