Strange popping issue
Started by oliphaunt, April 07, 2010, 11:45:07 PM
oliphaunt
I built this circuit on my breadboard:
It pops every time I turn it on and off (the breadboard is in a true bypass looper), but if I switch the 10u electrolytic cap out for a smaller value film cap it doesn't.  I have tried several 10u caps.  Pull down resistors don't help.  Any thoughts?
differo
try 100k after 10mF and before 'boost' pot to the ground.
My youtube channel:
http://www.youtube.com/user/BeToneful
Rebote2.5,MXR dist+,DrBoogie,BSIAB2,Ross Compressor&Phaser,MXR EnvFilt &Noise Gate,TS808,Condor CabSim,SansampGT2,Fraverb,Small Clone,TremLune,ValveCaster
Varao
I know it's been a while.....  but why not use a poly film cap?  They sound better than electrolytics.  With the 10K pot and a .47uF cap your cutoff frequency is 34Hz, which will even work for bass guitar.
(a) did you get the electro polarity correct, more positive voltage on the + side?
(b) have you measured for DC on the output?
As another thought, it takes a long time for 10uF to fill up through a 100K resistor.
