dr. boogey hizzzzzzz
Started by richon, April 09, 2010, 06:19:34 PM
richon
is it the only way to reduce the hiss (besides more filtering ) by reducing the bias on each stage?  ???
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
Brymus
12n cap at input to ground
Shielded wire for input /output/gain/treble
BIG improvement
richon
i've done this....
right now the only real good way to reduce noise is adding more and bigger caps paraleled to the trimers
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
Brymus
#3
Hmmm, mine is open/unboxed and uses unshielded wire at the moment and with the 12n to ground it has almost no hiss.
Maybe your layout or lead dress is adding noise ?
Which layout did you use ?
EDIT-Also are you using a battery or power supply to power it with ?
richon
the layout is mine...  and I'm testing with 9v batery.
is there a ceeling from where to cut the treble to make is less HIZZ intensive?
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
oldrocker
Humbuckers or single coil?
