Metal Simplex vero layout.
Started by jpm83, August 11, 2007, 12:20:56 PM
jpm83
Here is it, unverified.
Janne
oskar
R4, R5 divider provides a 4.5 ref. Voltage.
But your taking the ref R6 from 0V/ ground... not?
R6 top pin should jump down one step.
jpm83
Quote from: oskar on August 11, 2007, 12:28:30 PM
That was a different beast in the first picture, sorry. I fixed that thing to the original thread of that layout.
Janne
Toney
 I don't have the schem handy but a suggestion...
If you flip C1 up 3 lines and add a trace cut at row 'e' you'll save a line and keep the input clear of ground.
You can omit row 'b' too.
Looks good Janne.
jpm83
Quote from: Toney on August 12, 2007, 10:05:41 PM
Looks good Janne.
Thanks.
Janne
Toney
I am building one of these now.
Just a quick note for anyone else...
On this layout R2 must connect to Q1 at the collector (line f) not the base, then it should work.
