Anyone knows tested mods for Boss ODB-3?
Started by gigimarga, April 12, 2010, 05:35:31 PM
gigimarga
Hello,
I've just bought a Boss ODB-3 and I like it, except the shrilling highs from some settings.
The schematic can be found here (thanks to mrslunk!): http://www.diystompboxes.com/smfforum/index.php?topic=76569.0.
The only mods that I found are here: http://www.talkbass.com/forum/showthread.php?t=369882.
Indyguitarist seems to know some mods for it: http://www.indy-guitarist.com/inc/sdetail/102.
Excepting the well-known clipping section mods, anyone knows (or tried) other mods?
Thanks all!
gigimarga
Very strange tone controls for my knowledges...
gigimarga
Another try...seems to be like a Boss Blues Driver BD-2...but I have no ideea how to modify it :(
mrslunk
what do you want to get out of modifying it?
wampcat1
easy mod to make it much nicer:
c10: 1uf
r31: 1k
c8: .001uf
for more smoother compressed tone, change d2 and d3 to 1n4148's
gigimarga
Quote from: mrslunk on April 15, 2010, 06:48:25 PM
Hello mrslunk,
I want to eliminate some shrilling highs and to try to get a fatter distorsion, too (like a Woolly Mammoth). I tried it on guitar, too, and it sounded not very good :)
Thx a lot!
gigimarga
Quote from: wampcat1 on April 16, 2010, 09:18:01 AM
c10: 1uf
r31: 1k
c8: .001uf
gigimarga
c10: 1uf
r31: 1k
c8: .001uf
Thx a lot Brian!
How it will sound with these mods?
wampcat1
Quote from: gigimarga on April 16, 2010, 11:11:18 AM
c10: 1uf
r31: 1k
c8: .001uf
Thx a lot Brian!
hmmm.... it's been about 4 years since I had the pedal... IIRC, it just sounded much smoother and fatter but less 'flabby' as well.
bw
gigimarga
Quote from: wampcat1 on April 16, 2010, 01:00:42 PM
c10: 1uf
r31: 1k
c8: .001uf
Thx a lot Brian!
bw
OK...I will try as soon as possible :)
mrslunk
Here's what i'd suggest:
in the clipping path, there are 7 caps.
Try bypassing each cap with another cap of the same size. Remeber that capacitors in parallel add...
If this gets you further away from the sound you want, you probably want to decrease the size of the initial cap.
Fatter distortion means you prolbably wanna increase the pre-clipping treble roll off slightlly, and maybe increase the gain a little.
Taming the shrill high's will mean you probably want to increase the treble bleed off across the clippers.
You could also tweak the distortion texture by using different diodes, I'd suggest that if you do, use 2 in series on each, ie: 2x1n4148 || 2x1n4148.
All the usual diode tricks should apply.
I'd focus my attention on the 330pf caps, the 1.8k/10uf and the 1.8k/0.1uF parts, making thorough use of my audio probe to work out what the circuit was doing, since i can't visualise what was happening.
I'm guessing(can someone with a more electronic trainig confirm) that the 2 back to back fets form an inverter. If that is the case, the 330pf's across the inverted/noninverted signals would cancel some treble and the 1.8k/10uF would bleed some of the low frequency content of the inverted path to ground, when combined via gain pot, this would introduce a low frequecy boost...
Changing the caps will change the locations of the rolloff, chaning the 1.8k resistor will change how much of a low freq boost you get.
gigimarga
WOW....very nice advices...thx a lot mrslunk!
gigimarga
c10: 1uf
r31: 1k
c8: .001uf
I made these very simple mods and ODB-3 sounds much better: fatter, without the shrilling highs!
When I will have more time, I want to tweak around the clipping section :)
Thx a lot Brian!
